Hello, sometime when I debug an application I make a mistake by forgetting the application running and start a new build.
That cause an error at the end of the build process "Permission error" and the application is not written to disk.
But with some of my application it take 30 min to build and I loose all this time.
So it could be useful to give the possibility to save as another name the application at the end of the build process when we get permission error on the file.
Thank you
Dany
