13 | |
11 | |
3 | |
3 | |
2 |
The Registry Settings within the Build Spec from an installer is using fixed values only.
It would be nice to have somthing like varaibles that contain the information that are entered on the page
"Productinformation" in the settings window from the installer.
Productname -> %productname
Productversion -> %productversion
User selected Path for installation -> %installdir
This would allow something like this:
The values {%productversion} etc. will be replaced during the setup with the real values. The %installdir contain
the selected installation dir from the user.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
