P@Anand
Application Control Items - Replace without disturbing the connected wires
Status: Completed
Issue fixed with Quick Drop Replace in LabVIEW 2015 and later. We have no further plans to address the issue with right-click Replace.
While replacing the Property nodes with Invoke node, Call by Reference, Start Asynchronous call and Wait on Asynchronus call, the primitives are shifting the origin disturbing the wires. So a cleanup is reaquired all the time whenever the items are replaced. It would be very helpful and infact time saving if this is corrected.
Place a Property Node in BD with the Error in and Out connected
Replace the Porperty Node with an Invoke Node
Repeat the same with other primitives
The same behaviour is not found when the Call by Reference, Start Asynchronous call and Wait on Asynchronus call primitives are replaced with one another.
6 Comments
PaulG.
Active Participant
Another instance where LabVIEW aggravates OCD Smiley Surprised
PaulG.
Retired
Darren
Proven Zealot
Yeah, this one really bugs me. Your idea exchange post is motivating me to fix the issue with Quick Drop Replace, which has the same problem...
P@Anand
Trusted Enthusiast
So we can expect some LabVIEW cleanup pretty soon!
Darren
Proven Zealot
Alrighty, I filed CAR 511000 on this issue (as it pertains to Quick Drop). Should be fixed in a future LabVIEW release.
AristosQueue (NI)
NI Employee (retired)
Unfortunately, fixing the C++ side requires significantly more effort, so non-quick drop replace isn't going to be fixed anywhere near as soon. Noted for future release consideration.
Darren
Proven Zealot
Status changed to: Completed
