I think the application builder should be able to generate a standalone applicationwithout the need to install the LabVIEW runtime engine, to reduce the user to install anduse the program to do the steps are too complicated or complex to install, or can becalled "hidden install" or "incidental installation", and will install all the files are placed in a program (such as VIPM installer). Best to install the non-LabVIEW files (like DOCdocuments, pictures, msi installation package, etc.).
