Front Panel array controls and indicators could have an optional (by default off) array dimensions field just under the array indices fields, that would display the current array dimensions and allow changing them if the array could be edited, such as for a control or for an indicator when not running.
If an array dimension is increased, it would fill in with the default value. If an array dimension is decreased, it would shorten by cutting from the end.
