| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
Array To Cluster Function, add Type to Convert Cluster
I rarely use this function, but when I do I always end up using Variant to Data function for my Cluster Type.
So I would like to add a Type terminal to convert cluster type.
If Type terminal is unwired, this function work as it in current version.
If it is wired then it will convert to cluster type, and further it can also be used to define cluster size. So this way we can adjust cluster size dynamically if cluster definition changed.
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Array-to-Cluster-Type/idi-p/1044021
