| User | Kudos |
| 13 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
Add support for array calculations in Formula Node.
Seems not that much of an effort, since LabVIEW is very array based.
Now only scalars can be dealt with.
(Mathscript is an add-on that can do this, however I would like to see this as base functionality).
