8 | |
6 | |
4 | |
3 | |
2 |
I would like DSC to have the ability to use array variables from a PLC as shared variables arrays. This is currently not supported, and adding individual variables to then make up an array is cumbersome. Using methods other than shared variables are not as portable, and equally cumbersome,
