Indicate when a wire is passing under an item, as opposed to when it is wired to the item. I had an error wire passing under the error conections for a object. I thought it was connected but it was not. I saw someone posted an idea for arrows, a bit too big. In a reply some else posted a note that there is a small gap shown in the wire. I could not see the gap, nor do I think it exists in LV2015SP1. I would suggest a clear gap or a thicker border at the point of connection to indicate the connection.
