6 | |
2 | |
2 | |
1 | |
1 |
With 6 or 8 input/output patterns it is extremely difficult to see difference between particular I/O. This is even more problematic you use for example INT32`s or other data types that have dark color as default.
One gets few pixels of dark blue with black border around it to make things even more difficult.
Suggestion:
- Make an Assigning Terminals mode where the icon with terminals gets enlarged eg. x4 and where all terminals are clearly visible.
- Do not add more black borders, just stick to the data type color.
- Add clear indication which controls and indicators have already their terminals assigned (general information). User by clicking can see which one is assigned to what terminal (as it is now)
Regards
Niklasson
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Connector-Pane-Editor/idi-p/1211569
