3 | |
3 | |
2 | |
2 | |
1 |
I have several LabVIEW applications that I work on, and each of them has a Perforce workspace associated. Every time I switch to a project that is in a new workspace, I have to dig through the SCC configuration menu to switch workspaces, which takes a while.
It would be really sweet if LabVIEW recognized that a project file was in source control, and associated the workspace with the project file. (Especially because I could have two application projects open, each in its own workspace.)
