It would be quite helpful if LabVIEW would automatically grow down a function when bringing a new wire to build array/string concatenate/build cluster/interleave arrays/build matrix/compound arithmetic, allowing the programmer to make a new connection to the function if the function currently does not have room for the connection.
Even better is if it would grow/insert where the wire is near the function, below an existing connection, similar to 'ADD INPUT'.
