13 | |
7 | |
3 | |
3 | |
3 |
Suppose you have a while loop containing a case state machine with several cases. Then later you decide to add a shift register. It's very time consuming to wire every case when you might need to alter the contents of the shift register in a single case. So when adding the shift register and the user connects the SR wires to one case, auto connect all the other cases internally.
