| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Hi there,
How many times you use tables in MicrosoftWord to reporting data from LabVIEW?
If you are Report Generation Toolkit user I believe you have already faced to the problem for autofitting columns.
Here you are a functionality that implements it.
Thanks in advance,
Álvaro
