| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 5 | |
| 4 |
This goes a bit with Christian's suggestion to separate edit time and run time front panel sizes.
While I do appreciate the alignment grid on the front panel I find it insufficient a lot of the times. What I would like to see is some alignment helpers similar to the ones that are provided in the form editor of MS Visual Studio:
All of these features should be available for a move as well as for a resize of the controls.
You can find screen shots of what I am talking about here and here.
