| User | Kudos |
| 13 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
Hi all,
Tried looking for this suggestion but could not find it so I'll bring it up:
Automatic Precisional Rounding of Write to Fractional String and/or Decimal according to input's bit-precision. Determines formatting string of and/or converts to string with the level of significant figures or precision inherent to the number and bit-precision of its input, all done automatically. Example: A single precision numeric, after arithmetic operation, expects a value of 0.52, but due to precision is representatively stored as 0.51999998903. When you wire this value into the Write to String but select "automatic" on the precision terminal, it truncates to the maximal precision theoretically (0.520000).
