Ryan Cattley
Automatically Save DaqMx Custom Scales in the project.
Status: Declined
I recently came across an issue where an application that I built refused to recognize my DaqMx device on a remote computer. I had custom scales that I made in DaqAssist. It turns out you have to create new scales in project explorer, call them something other than your arlready-built scales (the ones you created in DaqAssist), and manually go thorugh and select the newly created scales in each individual DaqAssist VI. This was a bit of a pain As I had various DaqAssist Vis spread thorughout my VI and sub VI's, and I had several scales to replicate.
LV should Automatically save custom scales created in DAQAssist to the project, thus avoiding having to manually create, rename, configure, and individually select new ones for each instance of Daqassist.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
