In LabVIEW 2014, sbRIO-9651 projects need a FPGA socket CLIP to be selected.
This FPGA socket CLIP can be user defined to select aspects like available FPGA pins.
By default, a user defined FPGA socket CLIP is saved in the National Instruments installation folder
or in the National Instruments user date folder. In other words, these FPGA socket CLIPs are not
saved with your LabVIEW project. This means you can forget to keep them by putting them under
configuration control (happened to me when my PC hard disk was changed) and other users will
not be able to use your LabVIEW project if you forget to provide the FPGA socket CLIP used
(happened to me when sharing my projects with NI engineers).
My suggestion is default behaviour of the CLIP generator should be changed.
This tool is used to select or create a sbRIO-9651 FPGA socket CLIP when creating a LabVIEW project.
I propose this tool should always save the created/selected CLIP under the project folder.
This would help to ensure the LabVIEW project contains everything associated with the project.
Optionally, it would helpful if the LabVIEW project dependencies showed FPGA CLIP usage.
I have unknowingly had a project using another's projects CLIP (especially when the CLIPs have
the same name).
