6 | |
2 | |
2 | |
2 | |
1 |
One thing I find myself doing all the time is rewiring the case structure error cluster in a new VI I created either through the Edit -> Create SubVI option. LabVIEW should have a way to automatically detect that the case structure is surrounding the whole VI and do it automatically or have a key you can hold to automatically wire the error case.
In the following image note that:
