Matthias_H
Automatically change wiring of SubVI if connector panes were changed
Status: Declined
If you change the connector panes of a SubVI with Ctrl + couse, the wiring of the SubVI should automatically change in all VIs which call the SubVI.
SubVI bevore changing rhe connector panes:
Changing the connector panes of the SubVI:
Should not give this result:
It should automaticallya change the wiring.
Debugging is also very difficult if 2 boolean connector panes were changed and the wiring of the SubVI will not change. So the caller VI is executable but the wires are swapped.
4 Comments
RavensFan
Knight of NI
What about the VI's that call the changed subVI that are not even open at the time you make the change?  Those can't change automatically.
SteveChandler
Trusted Enthusiast
There I go giving kudos to an idea without fully thinking it through! I'm not going to revoke it. I like the idea even though as you point out it is probably impossible to implement.
LabVIEW 2012
Darren
Proven Zealot
Status changed to: Declined
X.
Trusted Enthusiast
Trusted Enthusiast
