From time to time when we shut down a system that has a single controller controller two or more PXI chassis with MXI running between master and slaves, we forget to power on the slaves before the master. It would be great if the master power could control the slave chassis power and automatically power up and down correctly when you press the power button on the master system with the contoller in it.
