I would like an autoscale option on XY graphs that would autoscale both axes under the restriction that the resulting grids be square. That is, there are three parameters, not four - X offset, Y offset, and pixels-per-unit-for-both-X-and-Y.
So, if I graph, say, a bunch of points along (x/5)^2+Y^2 = 1...
Presently, if I graph that, it will look like a circle.
It would be nice if the resulting ellipse would look 5 times wider than it is tall.
