Darin.K
Autowire Property Nodes Created From Right-Click Menu
Status: New
Another request from my carpal tunnels here.  When you Right-Click and Create Indicator, you get the indicator wired to the terminal you selected.  When I right-click a reference and Create Property For... or Create Method For... I would like to get the PN/IN wired to the reference.  Right now it gets placed on the cursor when you select the property or method, and if you are unlucky, that can be a considerable distance from the terminal.  Now you have to drag it back into position, hope for autowiring to catch, or wire it up yourself.  I would much rather have it placed and wired automatically.
2 Comments
Ray.R
Knight of NI
Makes sense.
Nicholsj
I'd like to see this extended to about any node that is created from a wire.
Such as right-clicking a cluster wire and selecting the "Cluster, Class, & Variant Palette" then choosing "Unbundle By Name".  It'd be nice if  the "Unbundle by Name" was autowired to that cluster wire.
