gerh
Avoid hidden wires when a tunnel is dragged to another border
Status: New
Re-opening because LabVIEW NXG has been discontinued.
If You drag a tunnel of a loop, case structure or any other structure along the border over a corner, then
the connected wire becomes hidden behind the frame.
Sometimes, the wire looks alike it is connected to another wire instead - like in the example below.
I fell into that trap, because I've just seen the frame to the right and didn't expect, that the wire was
connected to the tunnel near the bottom.
Wouldn't it be great to break up the wire with a 90° corner and place it in the visible area?
More similar situations like this are posted in this thread:
http://forums.ni.com/t5/LabVIEW/wire-vanishes-behind-frame-of-case-structure/td-p/3221167
13 Comments
MichaelAivaliotis
Active Participant
Why can't LabVIEW just prevent you from putting objects or wires beneath structures? I never understood why LabVIEW allows this.
Michael Aivaliotis
VI Shots LLC
Darren
Proven Zealot
Status changed to: Completed
Available in LabVIEW NXG. When you move the tunnel from the top/bottom border of a structure to one of the sides, the resulting wires (both inside and outside the structure) are branched near the structure border so their vertical segments are no longer hidden under the structure borders.
Christina_R
Active Participant
Status changed to: New
Christina Rogers
