A simple Idea, though I'm not sure how simple it will be to execute.
Idea:
Make run-time environments (RTEs) backwards compatable.
Example:
Allow a LV2010 executable to run on a computer that only has the LV2012 RTE installed.
Benefit:
Saves hard drive space and install time. The LV RTEs are 600mb or so. Yes, hard drive space is far from being expensive, but it's annoying having to set through 5 installs just so you can run programs from 8.5, 2009, 2010, 2011, and 2012.
