10 | |
3 | |
2 | |
2 | |
2 |
In "Image Displays", Images are locked in the center position when the area is bigger than the image. Could we have more control onver their position ?
This feature would be useful for those who need to show images with different sizes in the same "Image Display" (not simultaneously).
I guess a new ImaqImage property like "center position" or "top left corner position" or "alignment" would be enough ?
Ghislain
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
