7 | |
6 | |
2 | |
2 | |
2 |
Another behavior that I find annoying isthe way LabVIEW manage the tabbing order with cluster.
Imagine a front panel with clusters (I thinkthat this is not unusual and that you will have no pain to imagine this). If acontrol embedded in a cluster has the key focus, the TAB key will only give thefocus to controls of this cluster. It is impossible to navigate outside thecluster!
In the following front panel I wouldexpect the following sequence when tabbing: Cluster_1.String_1 -> Cluster_1.String_2-> Cluster_1.String_3 -> Cluster_2.String_1 -> Cluster_2.String_2-> Cluster_2.String_3 -> Cluster_1.String_1 -> …
(According to the cluster tabbing order)
