I tried searching for a similar suggestion but couldn't find one but I would bet that this has been suggested several times.
Why is the routing to multiple adjacent array terminals (or similar) so terrible ? The top Build Array shows the standard routing chosen by LV when wiring from a group of refs starting at the top. Starting from the bottom isn't any better. The lower Build Array is what I always change it to !! Why is this not the standard routing ?
I'm sure all of you VI meisters with OCD can sympathise.
