MGiacomet
Bookmark Manager - Allow window to be resized to ANY size
Status: Declined
For some reason, one can't make the Bookmark Manager smaller than a certain size. I see no reason why...
It is already annoying that a lot of windows (Context Help, Search Results, Probe, etc.) are brought to the foreground when a person clicks on any LV window (VIs, etc.). Sometime a person needs to have other documents open (pdf, excel, etc). Not being able to even resize a window to any size is a hindrance to productivity.
Please make Bookmark Manager resizable to ANY size.
3 Comments
Christina_R
Active Participant
You can make this change yourself, with your current version of LabVIEW.
  1. Open <LabVIEW>\resource\dialog\BookmarkManager\managers\Default\Default Bookmark Manager.lvproj
  2. Open BMark_MainWindow.vi
  3. Open VI Properties (Ctrl-I).
  4. Select the Window Size category.
  5. Change the Minimum Panel Size to be width and height of 0.
 Be aware that at smaller sizes you may not be able to see the warning indicator when there are VIs that might have bookmarks that are not shown.
Christina Rogers
JKSH
Active Participant
Darren
Proven Zealot
Status changed to: Declined
