cyro
Bookmark Manager: Sort by column
please add the possibility to sort the bookmarks by column so I can choose to sort it by column "Bookmarks". I'm using it for documenting changes in different VIs like:
"#Change 20150125.1023 Removed code here....."
At the moment the bookmarks are sorted by VI name:
6 Comments
AristosQueue (NI)
NI Employee (retired)
The Bookmark Manager is completely user editable/replaceable. If you want functionality that is not already included, you can add it. Instructions are here:
https://decibel.ni.com/content/docs/DOC-31854
This idea will stay open. If enough users want this same functionality, we may incorporate it into the dialog that ships with LabVIEW.
(But, I'll be honest, this is a low priority feature and if you want this any time soon, modifying the Bookmark Manager yourself is the route to take.)
cyro
Thanks, I will try to modify it...
crossrulz
Knight of NI
I would actually consider this a duplicate of this: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Sort-arrow-in-column-headers-of-tables-and-listboxes/i...
If we had sortable column on tables, this idea would just come in as a bonus.
cyro
Yes you're right. Since the idea is from 2009 (with low priority...) I think it's time to implement it 😉
cyro
Darren
Proven Zealot
