Make possible that Boolean function accept error cluster as input as this example:
That is a nice little subVI Bob.
You may want to post a VI snippet of the code that is inside the subVI. You might have attached the subVI, but the setup of the Ideas Exchange is horrible and doesn't show file attachments.
