| User | Kudos |
| 11 | |
| 7 | |
| 7 | |
| 5 | |
| 4 |
This is not functional idea, but nevertheless - the point is that context help of boolean operation functions will contain not just text explanation of how does the function work, but also truth table. Thus it will be clearly seen all combinations of input values, and the resulting function output value - visualizing is always better than text description.
