8 | |
6 | |
4 | |
4 | |
4 |
Currently, it's not possible to build a 32-bit application using the 64-bit IDE. The work around is to write your code in the 64-bit version, and then open it in the 32-bit version to build the executable.
This idea is: Make it possible to build a 32-bit application in the 64-bit IDE.
An extension to this idea is: be able to build a OSX / Linux executable using the Windows IDE, and all various permutations of that (build Win exe on Linux, etc.). I would be OK with having to download and install some OSX/Linux libraries that would allow this.
