13 | |
11 | |
3 | |
3 | |
3 |
I have run into the problem from time to time that I create a new build specification in my project, hit the Build button in the setup dialog just to have the build hang or crash LabVIEW. To add insult to injury when I opened the project file again (sometimes even after recovery) that new build specification was not there since the project was not saved before building.
I have now trained myself to resist the temptation of hitting that Build button. Instead I will exit the dialog, save the project and then start the build via a right click.
I would really like to see the project file being saved before the build is executed.
