6 | |
2 | |
2 | |
1 | |
1 |
Many times a while loop needs a delay for one reason or another, even if its just to add a small delay so the program doesn't peg the processor. Having this would clean up BDs, and it would also act as a reminder to make sure your code doesn't peg the processor. (with nothing wired to it, it would default to zero)
