The built-in mouse wheel support for numeric controls is very convenient, as it allows comfortable tuning of values using the mouse wheel. But it has a potentially dangerous flaw: the default mode is "On Key Focus", which means that when you click inside the control, you can change its value by scrolling. But when they move the mouse somewhere else in the window and scroll (e.g. in order to zoom a graph), the focus stays in the numeric control, and you unintentionally change the value of the numeric control. This behavior has the potential to damage our hardware, as we are controlling high voltages and pressures using numeric controls.
Setting the Built-In Mouse Wheel Support property to "On Hover" keeps the values from changing when the mouse cursor is not above the control. But unfortunately it also changes the value when the control does not have the key focus, leading to another source of unintentional value changes.
So my suggestion is: If you add the option "On Hover AND Key Focus" to the Built-In Mouse Wheel Support property, accidental changes of values by scrolling could be prevented effectively.
Available in LabVIEW 2017 and later
