DVRs are extremely powerful, yet tedious to work with. Much of the coding is just a matter of following the exact same pattern over and over again, while making the code uglier. And I have yet to come up with a good way to reduce that coding overhead...
What if there was a built-in DVR call wrapper that allowed direct access to VIs?
The UI experience could be a hybrid of the Static VI Reference and Call by Reference functions: drop the "DVR Call Wrapper" on the block diagram, drag your VI into it, then wire it up directly.
It could have options for write and read-only. And it could have right-click options for changing default error behavior.
My standard use case would be class calls specifically, but I don't see a reason this couldn't be applied to any data type -- although some serious thought would have to go into expected behavior in terms of which terminal to treat as the DVR (although this could be dynamic based on which terminal a DVR is wired into, or maybe even settable on the wrapper).
A tool like this would likely save me countless hours of development time, and make it less likely that I'd make coding mistakes while writing routine code.
Have Dynamic Dispatching terminals accept Data Value references of the class or any child class. - N...
