11 | |
8 | |
3 | |
3 | |
2 |
When you pass a wire from within a case structure to outside a case structure, you have an option of "Use default if unwired".
If we had additionally an option for "Retain Current Value", this would simplify and prevent needless wiring, especially if we are using the state machine pattern. See images below for use case.
