13 | |
7 | |
3 | |
3 | |
3 |
I want to suggest Case Structure Selector comparison to dynamically changeable values.
Now Case Structure Selector compared to constant Boolean/eNum/Numeric/String values.
I suggest to compare the Selector input to External Inputs, for Example:
If String control wired to selector equal to C control then do the C tab content.
I have experienced similar problems many times when I need to compare the selector to a dynamically changeable variable.
Of course, there are other solutions but I think my solution may be useful.
