When one has to delete several cases from a case structure (for whatever reason) it would be fine to have the possibility to delete the desired cases within the "Rearrange Cases" dialog window
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Easier-handling-of-Case-structures/idi-p/3787384
(The other idea is newer, but it also has 4x more kudos than this one)
