| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 2 | |
| 2 |
This subject has been touched on briefly, but only in a post that started out just suggesting an indication of whether or not a case structure is case insensitive. This has been implemented since then, of course.
What I'd like to bring to the surface again is the case sensitivity. The mention of this in the previous post was suggesting that case insensitivity be made the default. I don't agree with this - especially with the repercussions it could have on converting older code.
However, I think it would certainly be useful and acceptable to add a checkbox to the "Block Diagram >> General" options for "Case structures case insensitive by default" (see screenshot). This would not break previous code, since turning it on would only effect case structures created after turning it on. Additionally, the "default default" would still be case insensitive, but programmers that do use string-based case selection could leverage this to their advantage (and not deal with forgetting to turn it on via the right-click option).
