My 2 cents: would be nice to have optional tabs on the case structure similar to what we have in modern browsers like chrome. If dont have gazillion cases then this would be a very comfortable way to switch between cases. Arrows at the side shift the cases. The active case is color coded and slightly overlapping the surrounding cases.
Warning: MS paint artwork below! 🙂
