| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 2 | |
| 2 |
Using ctrl + scroll for switching between the cases is somewhat hard to use, because when you have lots of cases its difficult to remember what is the order of them so its harder to ctrl scroll the one you looking for than to go to the case selector. Moreover if you work with bigger sized structures (which happens sometimes) you may not even have the case selector on your screen so if you ctrl scroll, you can only deduct which case you see by the visible part of the code itself. That doesnt work for me, I always go to the selector.
But what if when the user uses ctrl + scroll a small popup would appear at the mouse pointer and when the user scrolls up and down the highligh would move up and down selecting any case in the given structure?
This would highly increase the usability.
Applicable to the Event structure as well.
