11 | |
7 | |
3 | |
2 | |
2 |
The idea is to change Equal? function in a way, that it will be configurable, and will have one input as function "Equal To 0?". Sometimes you need to evaluate number of loops execution in While Loop (or not just it), and when you put standard Equal? function, some of wires will be not aligned in a straight line (either which is connected to Index output, or which is connected to Loop Condition), and you need to move up/down one of terminals.
So, you can see it from the attached picture.
