| User | Kudos |
| 13 | |
| 11 | |
| 6 | |
| 6 | |
| 4 |
While I was editing one of the subvi’s in my project I discovered that the wire to the ErrorCluster indicator was gone.
When this is not seen during, editing it will stay unnoticed until there is an error. You never know when this will be.
This will be solved if an ErrorCluster indicator that is not connected will result in a broken arrow.
It can also be solved to set the default value of the ErrorCluster indicators in ‘errclust.llb’ into:
