6 | |
2 | |
2 | |
1 | |
1 |
Inspired by a breakpoint discussion I looked at some Menu Selections that I do not use.
View>>Getting started Window... is one of them. Don't get me wrong! I like the GSW it has many useful features like all my pinned items, online links, the RSS feed.... Basically all the features that justified the new GSW in the first place BUT, it opens "Modal" and closes after the first action If I want to do a few things I need to reopen the GSW and of course I can't do anything else while the GSW is open
BUT! I thought to myself, "Jeff," I said to myself "wouldn't it be just peachy keen if the GSW opened Floating (Hide while LabVIEW is not active) when launched from the Menu?" After all FP.Behavior is run-time settable.
After much patting myself on the back for such a brilliant thought I figured I had better share that super-dooper idea with the community!
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
