As a LabVIEW programmer, I might spend a bit too much time trying to make my block diagram neat.
Hence this idea. I didn't find a similar idea posted so it might not be that interesting for others... Anyway, here it is.
It would be nice to have a more compact icon for fundamental VIs that only have 1 input and 1 output. Some of them are already in the 1x1 Pattern but others not. Like the Increment, Decrement, etc.
Here is what it would look like:
This would help to have cleaner code when using theses VI close to other wires when using clusters.
National Instruments will not be implementing this idea. See the idea discussion thread for more information.
