6 | |
6 | |
3 | |
2 | |
2 |
Background information:
Templates have two personalities, depending on how they are opened.
This is all reasonable! 🙂
It becomes a little bit confusing if we insert a VI into a diagram using the function palette (Select a VI...):
Current behavior: we get the *.vit inserted into the diagram. This is probably not what we really want in the typical case.
Desired behavior: We should get a plain VI inserted into the diagram. That VI should contain the template code and should be named according to the convention in point (2) above.
Idea Suggestion:
When inserting a VI template (*.vit) via the function palette, it should not insert as a template, but it should insert as a plain VI containing the template code.
(It might even be more reasonable in general if templates would always open as VIs (e.g. in case (1) above). We can always re-save them as templates if desired! I am not suggesting this yet, but it could be another idea in the future depending on how this idea is received. ;))
