A few special functions are incorrectly named in the LabVIEW documentation.
- the incomplete gamma function VI returns the regularized lower incomplete gamma function (as is the case in LabWindows/CVI).
- the incomplete beta function VI returns the regularized incomplete beta function.
Suggestion: change the description (and name) of these VIs to reflect their common mathematical definition.
Valid at least until LabVIEW 2013 SP1.
Moved to CAR database: CAR 633231
