I didn't see this in a search, but wouldn't be surprised if it is already here.
I personally hate auto growing structures. I find I spend more time downsizing them after laying out the internals than I do increasing the size when it is turned off. So I have the gloabl setting turned off, so all structures I create do not auto grow.
The problem? This doesn't override the structures auto grow setting. So, if I get code from someone else who had it turned on, then I have auto growing structures.
I see 3 potential solutions:
This would allow programmers with different preferences to both use the same code and not be annoyed by not having the desired behavior. I think #3 is probably the best solution to the problem, as you can maintain existing behavior and simply AND it with the new global setting.
